subscription
AJ242
Hi I would to change 3 phones over from a Telus business plan and keep the same phone number and billing address and email address. Could you help me please?
2 REPLIES 2
fixin1
@AJ242 - Public Mobile only has 1 phone number per account, so you would have to activate and port each line on a separate email each.
You can keep the same billing address and phone numbers, btw PM only allows Credit / Debit / Prepaid cards first then you can buy Public Mobile Payment Vouchers.
For the numbers, make sure your TELUS Business numbers / account has no port block enabled or else your number may not get ported. And use your TELUS Business Account # and the phone numbers to activate.
And if you need it instantly, you can get an eSIM for $5 FREE (Although you will need to get a supported model, just search up {Smartphone} eSIM. Physical SIM is $10 FREE.
And use the Public Mobile app on the Apple App Store and Google Play store to activate.
@AJ242 PM system is one email for one account, so you will need to use 3 different email addresses to setup the accounts
And remember to download Public Mobile app and start subscription there
after you activate the first one, use the referral code to activate the other two
