sim card
jcshrimp
I have recently bought a new sim card thinking I had to do that to change my phone number. I threw out the old sim card thinking I didnt need it and just paid $80.00 on my current account. I cannot activate the new sim card under the current account.. what do I do Now.. Theres no phone number I can call to get help
@jcshrimp  you paid $80.   Is your account showing Active now?
If so, it's not too bad, maybe just one more step for SIM Swap,  you can use this direct link to open a Sim Swap ticket
https://urlshortner.tiia.ai/-H7DB-
Only one way to you fix it explanation to moderator Team and the are nice service the will 100% help you
you have to Submit a ticket to a moderator.
Here’s when and how to contact the Moderator Team:
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
  • or you can send a private message to Moderator_Team by Click here.
  • You’ll need to be logged in to your Community account for the link to work.
  • In your message put it, please include.
  • your account number,
  • your phone number,
  • your account PIN,
  • explanation to them nice Team and nice service
      Good Luck
dabr
@jcshrimp    SIM changes require moderator help.  Submit a ticket via chatbot and follow prompts after typing "SIM swap" here: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
If unable to submit a ticket try sending a private message to Moderator_Team here:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
