08-17-2022 02:37 PM - last edited on 08-17-2022 06:31 PM by computergeek541
i cannot send text messages as it says sim card is locked and looking for 4 digit number which i dont know
08-17-2022 02:40 PM
HI @Stephmcg can you also not able to make phone calls or connect Mobile data?
if it is the SIM card lock PIN you are talking about , open ticket with CS agent for SIM card PUK:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Unlock a phone
then Click "Sim card PUK"
next Click "Contact Us"
finally Click "Click her to submit a ticket"
08-17-2022 02:39 PM
@Stephmcg hi if your phone is sim locked
you need to contact a customer service agent
you will need to open a ticket, to speak to a customer service agent Click here mention sim locked you can check for a response in your community envelope top right corner next to your avatar, or if you are having issues with Simon you can send private message to a CS Agent here: https://bit.ly/2GGCJzH
