sim card disbled
reetmintu
popping
@reetmintu
Which phone are you using?
Do you have a dual SIM phone?
- Click on the enable/disable SIM card toggle switch.
- Take your SIM card out and restart your phone.  Insert your SIM card.  Let us know the result.
hairbag1
Please describe "disabled". Was it broken or did it die by itself ?
Edit, @Anonymous got there first !!
@reetmintu- Is there a specific problem?  Can you give some more details?
