06-20-2022 09:45 AM
Hi,
I have a samsung SGH-S275M flip phone.
I have a 15$ plan that I registered my Credit card on it for automatic payment.
My last provider was bell. I call my provider to get my unlocke pin number. I receive my unlock network code to unlock my phone.
I made a mistake while putting the unlock number. Now when I put Public mobile sim card in my phone it says: ( Phone Freeze SIM unavailable. Contact your service provider.) And the only thing i'm able to do is '' SOS call''
Please someone help me. I've been surfing the net for the past week to found a solution.
Thank you!
06-20-2022 05:58 PM
Thanks @computergeek541 , I should said 3G and LTE 🙂
06-20-2022 05:56 PM
@hTideGnow wrote:With PM network, you will need a phone that is 3G or LTE
Let's remember that without the "3g" network, there will be no voice/phone call services.
06-20-2022 12:25 PM
HI @annemarie1948 this is a GSM phone on 2G only. With PM network, you will need a phone that is 3G or LTE
https://www.mobosdata.com/phone/samsung-sgh-s275m/
06-20-2022 12:18 PM
This phone operates on GSM - 2G.
2G is an old discontinued frequency not used in Canada and US.
06-20-2022 10:02 AM
Did you reboot your phone? Remove SIM card and in-insert again? Get same message?
Looks like you will need two codes now.
Unfreeze code or Master code (need to call Bell again for code or Samsung directly)
then
Network unlock code (given to you already)
06-20-2022 09:53 AM
See this youtube. Might help even it is different Samsung.
https://www.youtube.com/watch?v=Go7mSJpF8Ws
Did you try calling Samsung support?
06-20-2022 09:52 AM
@annemarie1948 hi samsung has online help you can get a master unlock code from them
