3 weeks ago
3 weeks ago
hi @Roscoe13
if you meant add-on, they are only 15 days long and need to buy one after another if you want more than 15 days
but if you go for 2 months, change to those Canada US plan, cheaper and easier. Many of those Canada US plans are cheap enough that you can keep the plan after you US trip. Or you can change back to Canada only plan after
3 weeks ago - last edited 3 weeks ago
Hey @Roscoe13
You can't buy 2 months worth of addons consecutively but you can buy a Canada/US plan and use it for 60 days then cancel.
I think right now the best thing to do in my opinion is to start a secondary account, and get the $30 20GB Canada/US plan. There is a 50% off deal right now. We're not allowed to post links here so I'll send it to your mailbox up top.
