No Service
Xul
I had my service cut off cause of stolen visa card. Paid up in full with New visa card but still no service.
hi @Xul
reboot the phone once more time
if same, ask support agent to check and confirm
 please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
@Xul  Did you report the phone stolen / lost turn that back off if you did and try to reboot the phone . If still no luck
send  direct  private message to support .
send  a  private message   To CS_Agent
eddieO
@Xul try restarting your phone. It may take a short time to get the account updated but you can try contacting a CS agent to see if everything is good on their end.
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
