07-14-2023 07:56 PM
i have only 8 minutes left of my 100 min on my plan..I am going on a road trip for 10 days to the US. If I buy an add on US roaming for $15 does that extend my time.thx
07-14-2023 08:56 PM
To directly answer your question, @frustrated9 , YES, it does, however ONLY while within the USA with the add-on you select.
Unlimited U.S. Talk and Text Bundle, $15
However don't confuse the US add-on with the 100 outgoing minutes included with the $15 plan.
They are completely unrelated.
Once you return to Canada, you'll still only have 8 minutes remaining on your plan minutes (presuming the plan doesn't renew while away)
If you have any questions, fire away.
07-14-2023 08:43 PM
@frustrated9 - plan minutes, texts and data are for use whilst in Canada.
Roaming addons are for use whilst in USA.
07-14-2023 08:05 PM
Your plan minutes have no effect on the roaming add-on. The roaming add-on is unlimited...in the states.
