06-01-2019 11:40 AM - edited 01-05-2022 05:10 AM
1: try to register but would not accept email address, so I used a different one, but why did it not accept first one??
2: brand new sim but get invalid sim error whilst registering, luckily i had another, but what do I do about the invalid one, can it be fixed or will PM send me a replacement.
3: I completed the refer a friend section but it seems to have not been accepted ??
Joining Public
06-01-2019 01:19 PM
Thank you for your reply
06-01-2019 12:49 PM
@Anotherusername wrote:1: try to register but would not accept email address, so I used a different one, but why did it not accept first one??
Maybe a typo or it has been used before in the system from a previous account?
Invalid sim usualy occur because the sim was previously activated or your browser crashed during activattion. If your browser crashed you should still be able to use it once the activation lock clears for that SIM.
Your $10 credit will appear in your account within 72 hours. Check with your friend to see if got the text for the referral. If not you need to notify PM and they will add it.To contact Public Mobile click here. The link sends you to the private message function and adds the moderator team as recipient for a private message. You just have to enter a title and text in the body of the message describing the problem and post. The message will be received by the moderator team and they will respond to it. You will receive the response in your private message inbox.
06-01-2019 12:09 PM
Did you have a previous PM or Koodo account and used that email address for account purposes. That is one reason.
Where did you purchase the invalid SIM card? You might want to try to return to vendor or if Public mobile contact moderator.
You should get the $10 credit within 72 horus (usually 24 hours though). If you have not received, you should contact moderator via private messaging.
Send a private message to moderator through the following link :
06-01-2019 12:08 PM
Try to contact a moderator.
Moderator can be reached at
