09-30-2024
09:24 PM
09-30-2024
10:27 PM
computergeek541
Hi After My 100 minutes are over, I was not able to use my add on balance of 500 minutes. Then I paid 5 dollars for another add on and now my new balance is 500 minutes, but I lost all the previous add on balance. Can I get that balance back please. Also, Will I be able to use this add on balance? Thanks.
09-30-2024 09:28 PM
HI @monalisa
the previous addon balance as to those you received from previous Christmas? Maybe they were used up and you weren't aware? that could explain why it didn't kick in and you have to pay $5 for another 500 mins
but ask PM support agent to check and confirm
please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
09-30-2024 09:27 PM
ask PM to check the addon history for you
Just open ticket with PM using the Orange Chatbot icon on the lower right. Type the question Submit ticket and select Contact Us to get to ticket open screen
or message them using this link:
