09-19-2023 03:23 PM
I purchased US roaming but it never worked. How do I get my money back?
09-19-2023 03:26 PM
@Ken99 You need to ask support for that , here’s a direct link to them.
send a private message To CS_Agents click
VVVVV Link below VVVVV
09-19-2023 03:26 PM
HI @Ken99
you can submit ticket to CS agent here:
But are you still in US? did you try to manually connect to T-Mobile or AT&T ? Try if you are still there
And did you enable Roaming data and VoLTE?
Where US you are now at or were?
09-19-2023 03:24 PM
If you're back now then contact support here:
Let us know if you're still in the US.
09-19-2023 03:24 PM - edited 09-19-2023 03:25 PM
Please click this link below to message customer service, PM is usually no refunds but you might be able to get one depending on the agent you get:
Keep an eye on your mailbox here as that is where your reply will come in (envelope icon on desktop, click your avatar icon in the corner and then click messages if on mobile).
Which roaming add-on did you purchase? Did you turn on data roaming and then connect to T-Mobile or AT&T? Many had more success with T-Mobile
