referral
loumar_
I provided my referral code to my friend, who just signed up with Public Mobile
How long before I see $10 rewards bonus get added to my account and his ?
Louis
@DennyCrane wrote:
You don't get $10, they do; and it takes a month for it to show up for them from what i remember.
You get $1/month, or the associated points if you're on the new rewards system.
The $10 for the new customer usually shows up the next day, but as others have stated, Public Mobile's official information says within 72 hours.
DennyCrane
loumar_
Thank you all for response, I will keep looking
@loumar_  - $10 should show up within 72 hours of activation.
The $1/1 Point should show up in your account sooner. So check your My Rewards.
If it goes beyond 72 hours and nothing shows up, have your friend submit a ticket to request it be added via CSA.
­­­Public Mobile Representatives customer support­­­ agents (CSA) can be contacted by either two methods, found here:
@loumar_
It will take 72 hours to have the $10 credit added to your friend’s account and you will get $1 or 1 point/month depending on what reward system you are on.
@loumar_  Your friend should see it with In  72 hours of activation , did your receive the cha Ching text that a $1 reward added to your account
