12-27-2023 10:04 AM
i'd like to cancel the transferring to public mobile which i did a hour ago
I called the previous service provider, they said i have to call public mobile for it
How can i contact public mobile?
Zhen
12-27-2023 04:14 PM
Hi Phil,
I can login to see page overview below. Maybe as Handy1 advised it takes some time to show all pages correctly, I will await to see...
https://myaccount.publicmobile.ca/en/account/overview
if i navigate to below
it shows error
SORRY, WE DIDN’T FIND WHAT YOU WERE LOOKING FOR.
Looks like the page you are looking for is unavailable or undergoing maintenance. (Error Code : 404)
12-27-2023 01:53 PM - edited 12-27-2023 01:54 PM
@causacn2 I'm a bit lost with the first part of your question, perhaps @Handy1 or someone else can help. For the second part if you are not seeing Profile look at the bottom left of the page for a > or a + depending on device/app and tap that then a menu will slide out with Profile. Edit, ok I see @Handy1 responded, not sure why I didn't have those messages just now.
12-27-2023 01:13 PM
great, thanks again Handy1
12-27-2023 01:09 PM
@causacn2 Yes just ask support at same time , and not the app and website both display differently . New accounts take a bit before they show everything in the typical fashion
12-27-2023 01:06 PM
thanks Handy1!
Lastly i did transferring a phone number from other service provider to public mobile, it works.
the new problem made by me was i did that transfer using existing public mobile # and account (login profile transfer), which causes the existing public mubile # not working (its public sim is taken over by new transferring #) 😞
I is advised to purchase a new public mobile sim ard, and do that online to reactivate the phone# with new publicmobile #
can i also ask this to csa agent or there is another link specificallly forit?
One more question for the already transferred # to public mobile which i did hous ago
it works,, but when i login public mobile web portal, i can only see overview. the profile is gone
can i get profile showing up as before?
Regards
Zhen
12-27-2023 12:04 PM
@causacn2 Here’s the link for support
send a private message To CS_Agents
12-27-2023 10:23 AM
@causacn2 It’s been sent to your community in box . Or use this link to it
12-27-2023 10:20 AM - edited 12-27-2023 10:22 AM
@causacn2 Remember that PM is a prepaid provider and as such if you leave after paying it would not be pro-rated so you are forfeiting the plan that you already paid for. You can try private messaging customer service to see if they might consider a refund but no guarantees
Their reply will be in your community inbox, where you should also find @Handy1 's message with the phone number
12-27-2023 10:16 AM
Yes, I did from profile transfer number and clicked confirmed
now it is in progress,
Can you send porting team number
Thanks Handy1
12-27-2023 10:09 AM
@causacn2 Did you reply YES to the confirmation text to port ? From old provider . If so and it’s already transferred you will have to just port it out again . But I’ll send you the porting team number Leinster message and maybe they can cancel the transfer for you .
