referral code
jwon0421
Hello
When I was setting my account today,I  fogot  my referral code of my friend at that time.
so i did not enter referral code.
my fridend referral code is xxxxx
PLEASE APPLY Referral code  for my account discount .   thank you
edit by mimmo removed referal code
geopublic
@jwon0421  As others have mentioned you need to submit a ticket and ask the moderator to add the referral code.
@kerago wrote:
Not sure it's possible now otherwise anyone would ask for it. You need to address this to the  moderators, they might be able to do something.
They can do it.
kerago
will13am
@jwon0421 , only the moderators can apply the code after initial activation.  You will need to contact them.  The moderator team can be reached via private message using smartforms which is initiated by clicking on the ? on the lower right corner of the webpage or try using this link. The guided process will facilitate documentation of the issue or concern and the required resolution which will be submitted to the moderator team. Refer to this announcement link for additional details on smartforms and the ticketing system for moderator team interactions. Refer to the following knowledge base article for additional information on the moderator team.
hairbag1
Click the ? in lower right side of screen to start process of contacting a moderator for their help...they're the only ones who can help now.
