refer a friend
Beth27
if i refer a friend, do i get a reward?
7 REPLIES 7
@Beth27  Tell them about all the perks and low cost plans and how wonderful and helpfull the community is
Beth27
thanks. i hope i can find a friend so i could get a rewards
@Beth27  Welcome to public mobile !
Beth27
thanks. just new in here
Beth27
thank you. just new in public mobile
@Beth27  Yes your friend saves $10 and you get $1 for every month they stay if on old rewards or a 1point for each month they stay on pm if on the point system
LoveNature
@Beth27
yes you will get 1 point for new rewards or for old rewards you will get a $1
and your friend will get one time $10.
