11-06-2023 10:37 AM
Is there a link or code for referring a friend?
Please send an instruction what to do?
Joining Public
11-06-2023 10:51 AM
There's also a link at the top of the overview page called Sharing is caring. Give the link to the friend and it will start in to the sign up page keeping the link in memory. Then when you get to the payment screen the code will appear pre-entered. But after paying, the sign up has to be completed in the app.
11-06-2023 10:47 AM
thanks hTideGnow
11-06-2023 10:47 AM
thanks mojorising
11-06-2023 10:44 AM - edited 11-06-2023 10:55 AM
You can cut & paste your referral code (mix of 6 numbers and alpha) and share it by email for friends and family to use to avoid entering it by mistake.
11-06-2023 10:41 AM
HI @SH11
to be clear, when you friend activate, at Step 4, Order summary , make sure he click "Apply Promo and/or Referral code" then he can enter your code there
11-06-2023 10:39 AM - edited 11-06-2023 10:40 AM
Log into "My Account" and select "My rewards". there will be a code there for you to shar with a friend.
11-06-2023 10:39 AM
HI @SH11
login to your My Account, on the main page (Overview), scroll down to the bottom and you will see the referral code, pass to this your friend
When you friend activate, at the step with payment, there is an option to click for putting promo code or friend code, that's where your friend will put the code
