receiving error message when attempting to sign into my account
lcomeau1
i have just activated my new sim card and cannot access my account it continues to give me an error message
hycm53
What error message you get?
Since PM website has caches issue, so clear caches , cookies then using computer and private or incognito mode browser to login. For some mysteriously reasons, mobile device some times hard to login, so don't use mobile device to login.
Follow above method try login again.
Yummy
Public Mobile has web page cache issue so you might be looking at obsolete status. Click on little spinner refresh icons lower down. Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
Do NOT change password. Try to log in with credentials you know.
walker1
@lcomeau1
Try logging into your account using a browser in incognito or private mode instead.
Try again
@lcomeau1   what exact error message you got?
Couple thing, if you have dark them extension on Chrome, please disable it or use other browser
if you are using Chrome and  have the password saved, please do NOT click Login after you picked the saved username and password
Try login from Incognito mode or a different browser
If none of those help, please open ticket with PM support:
1.  Open ticket with Chatbot for faster response (2-48 hours), using direct link: https://publicmobile.ca/chatbot.
Start by typing "Forgot Login Information", then click "Contact Us",, then click "Click here to submit a ticket ↗"
2. if you have problem with Chatbot: Private message CS Agent at:
