03-27-2022
12:12 PM
03-27-2022
01:51 PM
Dunkman
I am trying to reactivate my plan after 60 day, but I receive the massage that my account is expired ,and I can not pay the amount due? why? Mehri xxxxxxx
Edit by Dunkman: removed personal information
03-27-2022 12:43 PM
Those options suggested should work. If it has only been 2 months you won't have to worry that your account and phone number are lost, once you get it reactivated you will be good to go.
03-27-2022 12:14 PM
Try:
Alternatively, try adding $1 more than your plan amount, then reactivate.
Then try using lost/stolen function, log off, then log on, and remove the lost/stolen function.
I'm guessing one of the above will get you going!!!
03-27-2022 12:14 PM - edited 03-27-2022 12:15 PM
To reactivate account, do manual pay, choose "Other" as payment type and pay your plan cost. Credit card has to be registered with PM. You can make only 2 attempts to pay this way. If it fails you will have to wait an hour to try again.
https://www.publicmobile.ca/en/on/get-help/articles/reactivate-a-suspended-plan
Service/plan should automatically reactivate.
If it doesn't reactivate then go to the plans or usage page and click on the lost stolen feature. Suspend your service. Log out/in. Resume your service. Your plan should automatically reactivate.
