03-27-2022 11:22 AM
if i upgrade my plan will i be automatically enrolled in on the new points system? (i would like to stay on the old pts system)
Plans
03-27-2022 12:58 PM
Fortunately, entry into the new Public Points system requires a series of steps under the new Public Points site.
The only other way you would be enrolled is if you activate a new service.
BTW, best to not do this.
03-27-2022 11:45 AM
Lucky for you.. You would not
Sighhhhhh
03-27-2022 11:43 AM
@only1utd wrote:if i upgrade my plan
Do a plan change on next renewal; do not do it change Now unless you really have to change it. Just saves you few $ that way.
03-27-2022 11:27 AM
No, you would not get enrolled into new Points system. All rewards stay as is same as accumulated rewards.
03-27-2022 11:24 AM
No. And don't call the old one points.
