rate plan
08-07-2023 12:40 PM
08-07-2023 01:40 PM - edited 08-07-2023 01:41 PM
If I remember correctly that plan was $35 plus tax when it was available, which would align with the $39.20 figure you're referencing (assuming a 12% sales tax). I wonder if you switched off of the legacy rewards and are now on the public points system? The new points system doesn't automatically give you discounts like the old rewards system. The old system would give you $2 off for auto pay, $1 off per referral, $1 off per year of loyalty etc. The new points systems accumulates points that you have to redeem for bill credits when you want them (not automatic).
08-07-2023 01:25 PM
my current subscription is 3 gb 3 g speed
08-07-2023 01:14 PM
just says loading
08-07-2023 01:12 PM
@skysteve1 try login again using Incognito mode
08-07-2023 01:10 PM
not sure what plan I am on
08-07-2023 01:05 PM
ok thanks
08-07-2023 01:04 PM
the plan ? cant see my plan, just says loading??
08-07-2023 12:57 PM
Just because we (I) prefer pre-tax around here, that's $28 and $35. Did you sign up here on a promotional offering before accepting the recent offer?
08-07-2023 12:55 PM
@skysteve1 wrote:for the last year I was paying $31.36 with taxes now it is $39.20, my wife is still paying $31.36
HI @skysteve1
your plan was on the old plan and you are not
you might have accepted an offer by text to change to a new plan
Get the $39 plan instead, it might suit your need more
08-07-2023 12:54 PM
Login to each account and look at the plan summary and payment history to see the breakdown. I.e. what is the base plan, what discounts came off etc. Knowing the total your card was charged still leaves out a lot of detail. Without more information we're all just guessing.
08-07-2023 12:51 PM
what plan you have and what you changed from?
If you don't like the plan you are having now, you can only change to plans available now. If your old plan is not showing up, then it is grandfathered and you cannot change it back. Sorry about that
But tell us what plan you have now and maybe we can suggest
08-07-2023 12:51 PM
08-07-2023 12:50 PM
Well, if you accepted the offer then there you go. Log in and change back down to whichever lesser plan you were on. The problem for you might be that if the plan is no longer available then you can't go back to it.
Also, click on all the little spinner refresh icons you see lower down to make sure you're seeing current info.
08-07-2023 12:49 PM
You can do it all online yourself. Just login to your account and go to your Profile section and change plan but change it on your next renewal date.
If you click on change Now, you will be charge for the current plan plus the new plan.
08-07-2023 12:47 PM - edited 08-07-2023 12:48 PM
@skysteve1 wrote:hi, I was paying about $29 I was offered a new plan now im paying $10 more same plan?
HI @skysteve1
you had a $35 plan earlier and have rewards to bring down to $29?
If it is, the new $39 plan is only a $4 difference, so you will be paying $4 more for a much better plan with more data, not the same plan, it has 20GB
https://subscribe.publicmobile.ca/en/on/activation/plans/20GB-4Gspeed
08-07-2023 12:47 PM
I wonder if you had some sort of welcome bonus that has expired? I don't ever recall seeing a $29 plan, so that's likely what it was. I'm assuming you have the $39/20GB plan?
08-07-2023 12:43 PM
08-07-2023 12:42 PM
Please elaborate. Are you trying to change your plan? Just as a heads up we are all customers on this forum.
08-07-2023 12:41 PM
I was offered a new plan, but now im paying way more, I want to return to my old plan
