"No service" on my iPhone 6 - after switching over from Wind
chocotofu
A couple days ago I switched from Wind to PM. I ported my number over when I switched. However, the PM SIM card doesn't work on my unlocked iPhone 6. I've tested the card out in my old Nexus 5 and it worked seemlessly.
I've tried deleting profiles, restoring it to factory settings through itunes. There are no APN settings for me to change as it doesn't show up in any of the settings.
Anyone know what the problem is??
Thanks.
12 REPLIES 12
Rockdaddy22
Obviously an issue with the phone, maybe it doesn't have the proper bands to run on this network.
chocotofu
The LTE was enabled, no prompt of any kind, all I see is no service in the status bar.
I also checked my imei and nothing is reported.
mohammedessam
@chocotofu
check to see if your iphone is blacklisted
just input the imei into this website and it will tell you if the phone has been reported lost/stolen
http://www.protectyourdata.ca/en/check-the-status-of-your-device-in-canada/
You should never buy iphone's from kijiji
very risky
jimmyche
Try enabling your LTE under setting > cellular > Cellular options
Is there any onscreen prompt? like no sim?
To me, there could only be 3 things.
The sim, The sim tray and the sim contacts in the phone.
It's a wild shot, but also try your phone, pm sim with another iphone sim tray.
Rockdaddy22
Never mind it's obviously unlocked
Rockdaddy22
Also how do you know it's unlocked?
Rockdaddy22
Could it be from china or some weird place, just curious. Have you tried your sim in a different unlocked phone? You might need to contact a mod.
http://productioncommunity.publicmobile.ca/t5/Announcements/Information-required-before-sending-a-me...
chocotofu
Phone was brought brand new, box unopened, off Kijiji.
Any more suggestions??
Rockdaddy22
Well apn has nothing to do with calls, so something's wrong with the phone, where is this phone from?
chocotofu
No service - so no data, no calling, no texting available.
I've had someone else pop their Fido sim card in and the iPhone worked right away and I used it on Wind before this, so the phone is unlocked.
My phone is also up-to-date with iOS 10.1.1
neilselden
Hi,
What version of iOS do you use?
Update to the latest and see if you can edit your APN settings.
If not, you'll have to go here to get access to your APN settings/.
Hope this helps,
Neil
Rockdaddy22
No service or no data? If no service, then your phones probably not unlocked.
