Cannot switch to a new plan
11-28-2024 08:33 AM
Hello
Looking to switch to the $29 can us Mex plan. But my list of plans only offers the $35 one. Why?
Thanks
My Account
Plans
11-28-2024 12:38 PM
Agreed
11-28-2024 12:38 PM
cool. that will be the best plan to get then
11-28-2024 12:35 PM - edited 11-28-2024 12:35 PM
@hTideGnow @Colbydog Already said he have $35 plan and changing to it .they confirming why they didn’t see the $29 plan either like @Anotherpaul778 didn’t see it and no work around for the $29 that current price plan option only
11-28-2024 12:32 PM
HI @Colbydog
You don't see it now but there is a workaround to unlock it if you see the $30 plan there on your My Account
You can first pick $30 plan and do a Change Now plan change , which of course you need to pay now and the remaining days on your current cycle will be wasted. With this, you might be able to unlock the $35 roaming plan, and you can then schedule a plan change on the following renewal day
11-28-2024 12:30 PM
I have the same issue, am on the $34 CAN/US plan and wanted to change to the $29 CAN/US/MEX 10GB plan. The only new MEX plans available for me are the $35/$45/$55. I contacted CS_Agent support a few times and they told me that it was a "system error" and also that it was for "new activations only". This is PM code word for you can not downgrade your 5G plan (ie: pay less).
As others noted, you could port out and then port back in. Bit of a hassle to do that IMO. Unless something way better pops up tomorrow from other cell companies, I'll renew to the $35 MEX plan on my next sub cycle.
11-28-2024 08:42 AM
@Anotherpaul778 My guess is because the plan you currently know is more then $29 now and PM really only wants people to upgrade plan price not downgrade plan price . And makes it harder to downgrade now . So short of porting number out and back in on desired plan we can only change to the plans that are available to us to switch to in our accounts . Some will tell you to ask support but they won’t help so it’s waste of both you and supports time . Only exception to that rule would be if you just activated in the last day/ or two but if you been existing customer the answer will be NO
11-28-2024 08:35 AM
PM now use targeted marketing and only show selected number of plans and not all. So, not everyone can switch to the $29 roaming plan. You an try asking support and see if they can help, but so far, many got declined
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit ticket by direct message:
