12-06-2022 07:27 PM
I applied for the promotion plan of 15GB by logging in to my account and clicked "Upgrade on renewal"
But on renewal the promotion plan was not applied and on top of it my services were discontinues saying I did not pay and then I logged into my account and simply clicked pay now using the SAME AUTOPAYMENT REGISTERED CARD and then services resumed.
I lost the promotion plan due to some fault of the service provider or technical glitch on their website or at their end
12-06-2022 07:30 PM
@asmipinki , did you account go into suspension due to auto payment failure? This does happen from time to time. If the payment card in the account is not expired then try reactivating manually. Don't worry about losing the plan, it should be there for you.
12-06-2022 07:30 PM
Auto-pay sometimes fail - not as much as before, but some still report this to be the case.
If you REALLY DID set up the plan to change to the promotional plan and it did not update on renewal, and further your auto-pay did not function, contact a Customer Support Agent to seek remedy.
12-06-2022 07:29 PM - edited 12-06-2022 07:32 PM
Sorry to hear about that problem you had.
To get help with that situation, you'll have to get in touch with a CSA from PM.
Before trying to get help, try logging into your account using a browser in incognito or private mode first. You might have gotten the new plan, after all. You might have been looking at old information.
12-06-2022 07:27 PM
Public Mobile has web page cache issue so you might be looking at obsolete status. Try using different browser. Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
