03-02-2023 01:48 PM
yesterday I have a problem with my phone that I wasn't able to make any calls or to receive calls but the texting worked well
today it's the opposite the talk is working well but the texting is not working
03-02-2023 02:13 PM
did the CSA get talk working or did you do something to get it happening ? Was this a porting issue or something else ? Let us all know what happened.
03-02-2023 01:58 PM
@softech OP says talk is working, now the issue is with texting.
03-02-2023 01:57 PM
@brochaadolf , oh man, yes, I recall you posting issues the last couple of days. This must be annoying.
Did you contact customer support (CSA) as mentioned in past posts?
Do you use imessage or Chat Features or regular SMS?
If your account status is Active, try:
03-02-2023 01:51 PM
There have been issue since yesterday for some people with both incoming and outgoing calls. Try to change to 3G only and see if it connects to the network at all with such settings
If both incoming and outgoing calls are not working, I suggest you to open a ticket with PM support and let them aware you are one of those, too
1. Please open ticket via Chatbot (need access to My Account): At https://publicmobile.ca/chatbot.
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
