05-30-2026
06:33 PM
05-31-2026
11:38 AM
Dunkman
It says phone number is invalid 514-xxx-xxxxI cannot proceed
Edit by Dunkman: removed personal information
05-31-2026 10:51 AM
is this from line you want to transfer also from Telus?
if it is , then you can activate a new temporary number first, then ask PM agent to manually port the line into PM
05-30-2026 08:36 PM
im with Telus mobile with 2 lines my first one worked but this one doesn’t seem to function and I paid for the subscription already
05-30-2026 07:44 PM
I am with other cell phone and trying to transfer my wife’s also but that is the one not working
05-30-2026 07:42 PM
Number is still active with Telus
05-30-2026 07:42 PM
No
05-30-2026 07:32 PM
are you using Koodo Prepaid now? if you are, you cannot request porting yet. you have to activate the PM service with a temporary new number. After it is activated, you can then submit a ticket and ask PM agent to manually port over the line
05-30-2026 06:41 PM
This is a Telus number so it should port over to PM as long as the number is still active.
Contact a CS_Agent for assistance:
05-30-2026 06:36 PM
Are you with PM already?
