texting
bernie_black
I recently switched to your service. People do not receive my texts and many have trouble answering my calls.
CSA_PM
Customer Support Agent
@ bernie_black
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
slusagm
Can you receive calls?
Make sure your old provider sim and eSIM removed or disabled.  Then Reboot phone and Reset Network Settings
But if you need PM to help, open ticket and ask them to re-provision sim
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
bernie_black
A follow up: I receive very few texts that are sent to me, and no one receives my responses. Many also say my calls get dropped.
