08-06-2021 06:46 PM - edited 01-06-2022 03:03 AM
it's been longer than 90 minutes and didn't receive a conformation text
08-06-2021 06:58 PM
Make sure that you have the old sim card in your phone when you're porting your phone. You should get a message from your old carrier asking to confirm if you would like to port your number. Your reply should be: YES.
The confirmation message can take a few minutes to come in. You have 90 minutes from the time of request.
if you didn't gettign the SMS do Reboot your phone.
what is mean for Rebooting the phone means to turn off your phone about 2 minutes and turn it back on.
08-06-2021
06:56 PM
08-06-2021
07:09 PM
ShawnC13
@mccmelc9 : You might. But I would suspect it would be expired.
Edited by ShawnC13: Phone number removed
08-06-2021 06:52 PM
coming to public
08-06-2021 06:51 PM
ok old
sim is in, will i get the text
08-06-2021 06:48 PM
@mccmelc9 : Are you coming or going? If coming, then you need to leave the old SIM in to reply to that text. If going then you need to leave this SIM in to reply to that text.
