07-22-2021 04:07 PM - edited 01-06-2022 03:03 AM
My current plan is the $15 plan with $4 rewards, therefore, I'm paying $11/month right now. I want to switch to the $25 plan (extra data), will my rewards follow through? Does this mean that I will pay $21/month after the plan upgrade? Thanks!
07-22-2021 06:08 PM
Its to my understanding that if you renew or change plans earlier thsn your full 30 day cycle that rewards will not be applied until the following renewal. Have I misunderstood this policy? thx
How much data do you typically use or think you would use on a monthly basis?
07-22-2021 05:03 PM
Yes.
07-22-2021 04:18 PM - edited 07-22-2021 04:24 PM
Yes your Rewards follow through for your account and for any plan earn the Rewards on your account not for the plan.
07-22-2021 04:09 PM
@shelleyli03 : Yes...and you're exactly correct.
