11-17-2022 06:59 PM
It has been over 2weeks now. Porting from Eastlink to PM. Calls, texts work on other PM customers. I can call Eastlink customers, but i cant send/receive texts, or receive calls from Eastlink customers. When I check my voicemail, it still says you have reached Eastlink. When I contact Eastlink, they say everything is done at their end. Ive reset network settings, reset, shut down, turned airplair mode off/on. Most of my contacts are with PM, so it seems like everything is OK, but not with other services.
11-20-2022 02:41 PM
Hi @Izabella2004 are you not receiving calls and text from anyone , not just from Eastlink customers?
sound like the porting was not completed You ported form a mobile line ?
there is a porting support team you can call and ask the status of the port. I will message you the number. Please check your Community inbox.
11-20-2022 02:35 PM
yes, it is a family plan
11-20-2022 02:35 PM
yes
11-17-2022 07:15 PM
Did you reply "YES" to the port authorization text which would have been sent from Eastlink upon porting your number to Public Mobile.
Is your Eastlink account still active?
11-17-2022 07:07 PM
@Izabella2004 wrote:It has been over 2weeks now. Porting from Eastlink to PM. Calls, texts work on other PM customers. I can call Eastlink customers, but i cant send/receive texts, or receive calls from Eastlink customers. When I check my voicemail, it still says you have reached Eastlink. When I contact Eastlink, they say everything is done at their end. Ive reset network settings, reset, shut down, turned airplair mode off/on. Most of my contacts are with PM, so it seems like everything is OK, but not with other services.
Which city is the phone number from? If the phone number is not from a city that Public Mobile also issues phone numbers for, the number cannot be ported to Public Mobile.
