Porting Issue
rayyanxumair
My number was ported from Lucky Mobile to Public Mobile using eSIM. Outgoing calls and mobile data work, but incoming calls do not reach my phone and go to an automated voicemail system instead. Lucky Mobile service is already inactive, so the port appears partially completed and inbound routing seems stuck.
What should I do?
1 REPLY 1
@rayyanxumair
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins.  If you are not receiving calls and text on your PM sim card, and only outgoing calls work, then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
But if you are unable to reach a live support with the phone number I sent you, please message the the support team using this link instead:
