10-24-2022 12:47 AM
Is Pixel 7 a compatible phone for use with public mobile network?
If yes, do I need to change any configurations on the Pixel 7 to make it work?
08-30-2023 01:43 AM
Yes, compatible, after purchasing pixel 7 a and public mobile sim, configure APN to have access to the internet. Here are the tutorial you might follow Google Pixel 7A Internet (APN) Settings
08-30-2023 01:40 AM - edited 08-30-2023 01:47 AM
Yes, compatible, after purchasing pixel 7 a and publicmobile sim, configure APN to have access to the internet here are the tutorial you might follow Public Mobile Canada APN Settings
10-24-2022 04:03 PM
@noaccountpls wrote:@tambrulee all phones work on public mobile CRTC made rules that mobile phones cannot be locked to one carrier anymore
That rule doesn't mean that all phones will work at Pubiic Mobile. There are many places to purchase phones other than from Canadian carriers.
10-24-2022 02:09 AM
10-24-2022 01:40 AM
Most definitely the Google Pixel 7 will work on PM.
Once you install the activated SIM, it will configure itself.
Are you planning to port your old number over to PM?
If you are, just remember to leave your old SIM in the phone and wait for the text confirming you are porting your old number over to PM.
Or if you are picking a new number, just power off the phone before installing the new SIM.
10-24-2022 01:24 AM
@tambrulee wrote:Is Pixel 7 a compatible phone for use with public mobile network?
No configuration changes are needed. Pixel phones have Public Mobile APN settings built in.
10-24-2022 01:18 AM
You can use the Pixel 7 with PM.
After activation, insert PM SIM card and restart your Pixel 7 to set up settings for PM automatically. If your data does not work, you need to configure the APN settings to get data working.
