phone switching to US roaming while in Canada
oldskier
I am currently in Sarnia On and my phone has switched to US Roaming. What can be done
@DDM69 wrote:
Turn off roaming on your phone.
That is true that roaming can be disabled, but on most current phone models, there is no setting labelled as such.  Any setting referring to roaming in the menus usually only refers to data roaming, a setting which won't enable nor prevent a phone from connecting to the roaming network.  Manually selecting the Public Mobile network would prevent all roaming.
DDM69
oldskier
tx will give it a try
Metal1967
@oldskier @You won’t be charged.. does it affect your service..? Can you still use it ?
