03-12-2023
02:48 PM
03-12-2023
03:18 PM
Lieux
my LG V30 imei xxxxxxxxx works with data & messaging but not voice calls...Help
03-12-2023 03:56 PM
If the helpful options provided above does not restore your calling services, let the Customer Support Agents know so they can have a look at the account/service.
03-12-2023 02:56 PM - edited 03-12-2023 02:58 PM
@diger this is a public forum and is dangerous to post your IMEI number hwre, please update the post and delete it
are you not getting both incoming and outgoing calls?
try to turn off the phone for 5 mins , then startup and try again
If still does ot work and if possible, try your sim card in another phone
@Dunkman @Lieux are you still online and can help to remove IMEI?
03-12-2023 02:52 PM
Try rebooting, resetting network settings or reinstalling sim card. Also try changing your preferred network on your phone to 3G.
