personal hotspot
Rlid2
I tried to set up a personal hotspot from my phone. I get the message that I have to contact Public mobile to enable personal hotspot on my account.  But I am not having any success in contacting  public mobile to do that . Any suggestions?
10 REPLIES 10
@NothingDone2Day wrote:
every time I change APN go out then back in it defaults back to isp.mb.com.   Any suggestions
On some Android devices, tapping back doesn't automatically save setting changes. You may need to select the menu and choose save.
NothingDone2Day
Rlid2
Thanks
@Rlid2 reboot the phone and try setup hotspot again, and check APN
,go Settings -> Cellular -> Cellular Data Network -> PERSONAL HOTSPOT / APN -> sp.mb.com , and  Leave Username and Password blank.
(if you see APN showing isp.mb.com, please update it by dropping the i and make it sp.mb.com
Chalupa_Batman
Hi @Rlid2
I myself have used my Public Mobile phone (iPhone XR) to hotspot my data to my Chromebook to surf the net. I had no problems at all. Depending on what phone you're using, you may wish to Google it and see if that helps. Most time I find, it's password related, in other words I type the wrong password or caps lock is on.
@computergeek541 wrote:
This is a device software issue. Public Mobile hasn't disabled hotspot.
Why would customer be getting message to contact Public Mobile ?
Rlid2
oh ok - that makes sense
Thanks
Rlid2
thank you
hairbag1
@Rlid2
use this link to message Customer Support..
added...watch the little envelop icon on top right side of page will be highlighted when they respond to you.
