07-30-2022 03:04 PM
Hello. Either my account isn't working (claims of suspension) or other problem(s) might have occurred. Please advise why I can't use my cellphone to call people when the payment was accepted and added. Thank you.
08-02-2022 10:14 AM
First, how much is your plan? $15? $25?
Can you login to My Account and check if the account status is active? Also, check if there is any amount there as Available Fund?
The fund could be there but wasn't used for renewal , or you might not have enough fund for your plan still.
Login to My Account first and please provide us the answer
08-02-2022 10:04 AM
Hello the message I get is: "Sorry we cannot complete your call since you don't have an active plan on your account". I had added (on Friday) $20 from a payment voucher and it stated it was added. When I attempted to make phone calls I kept receiving this message.
08-01-2022 10:32 AM
have you open ticket with PM CS agent yet? i think you should open it first while trying to make it work yourself
To open ticket:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
start by typing : Contact CS Agent
then Click "Contact Us"
then Click "Other"
finally Click "Click here to submit a ticket"
08-01-2022 10:22 AM - edited 10-21-2022 01:00 AM
First, is your account status showing Active or suspended?
Do you see any amount showing in Available Fund?
And , are you trying to access My Account via Desktop or Mobile ?
Desktop:
Mobile:
08-01-2022 10:16 AM
please give more detailed instructions as to how to correct this problem
07-31-2022 10:45 AM
Hello. I can't find the "plan/add-on" tab, please advise. It is not under "plans' as far as I can tell
07-30-2022 07:12 PM
@loki_hulgaard - did you just activate and have never had services, or were you suspended and just added funds to your account?
You will need to reactivate if your self serve (or when you call 611) is still saying suspended.
If it is Suspended status, but nothing is showing owing..
Try
If still issues reactivating the plan, ask CSA for assistance.
Public Mobile Representatives customer support agents (CSA) can be contacted by either two methods, found here:
07-30-2022 03:13 PM
did you load the voucher via *611 just now? it could take a bit more time if you laod it that way. Maybe 15 mins. Just reboot your phone once every couple mins until it works.
If you can login My Account, it is better as you can tell exactly if the amount is updated on the system and if it has applied towards reactivating your plan yet.
07-30-2022 03:07 PM - edited 10-02-2022 12:09 AM
Hi @loki_hulgaard did you just manually paid? If you did, restart your phone once
Also, what is showing in My Account? Active or suspended for status?
If suspended, any fund showing as Available Fund? Is there a button Reactive My Plan?
07-30-2022 03:06 PM
Some vouchers require 24h to become active. Where did you get your voucher?
07-30-2022 03:05 PM
Dial 611 to make sure acct is ACTIVE or something else.
Try restarting phone.
Try removing sim for a moment...then re-install it.
