pay extra add on whit rewards
Rabbi
can i only use my rewards, auto pay/refer a freind/coomunty
to pay my bill or olso to buy add on, us rooming/long distents
8 REPLIES 8
@Rabbiwrote:
@NDesai to be clear, its only on my first time?
Yes, after your first renewal, it will remain under Rewards.
Rabbi
@Taekgunwrote:
Yes, you can only use the auto-pay rewards because they get added to your "available balance".
Only when you activate. After the first renewal, they behave the same as other rewards.
Rabbi
@Taekgun auto pay is alwas for next bill ?
Taekgun
Rabbi
@Taekgun to be clear auto pay i can use for add on & referral credits and community rewards i can only use for my belonce
NDesai
No, you can't. Rewards are only used towards the renewal of your plan.
Taekgun
@Rabbi
You have to purchase add-ons from your "available balance".  If you just started, you may have balance available from your auto-pay rewards, but add-ons must be purchased from this amount.  If you don't have enough for an addon, you need to add funds.
The other referral credits and community rewards will only be deducted from your total owing for your 30/90 day plan.
To buy an add-on is typically a two step process of adding funds to your account and then purchasing the desired add-on.
