09-26-2022 07:22 PM
cant reset password to login to update payment info.
phone doesnt work because i think card expired ..
09-26-2022 08:01 PM - edited 09-26-2022 08:02 PM
please use the link above to create a support ticket
*customer support doesn't always respond promptly. please be patient and check your inbox every few hours to see if there is a response
09-26-2022 07:59 PM
If having issues about which email you signed up with (if you did register for a My Account), use the Forgot your password option to reset it and use possible emails it could be.
https://myaccount.publicmobile.ca/en/forgot-password
If an email is received (check spam/junk folder) then the email is likely registered.
If having browser issues, try clearing your browser's cache, or try a different browser or device. Or, even better, open a tab in incognito mode and access My Account that way.
09-26-2022 07:34 PM
@piaskow Click the down arrow on your second post and select edit from the menu and then delete your tel. # from the post as you're on an open public forum.
Have you ever created a self serve account? If not you still need customer support to help with creating your account now which requires an email as username and a password. Click the following link to get support for the self serve account or use the earlier link if you just need a password reset.
https://urlshortner.tiia.ai/XZxMjt
You can purchase a voucher from many retailers and add the funds by dialing 611 to restore your service while you wait to reset the password or create an account.
09-26-2022 07:29 PM - last edited on 09-26-2022 07:30 PM by computergeek541
or it is possible i dont have a login but im pretty sure i signed up online? either way i nee to login and get payment corrected xxx-xxx-xxxxx
09-26-2022 07:25 PM
@piaskow To reset the password you'll need to submit a ticket via chatbot here: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
For payment if it's urgent, then purchase a voucher from SDM, London Drugs, 7/11 or Shell and load the funds by dialing 611 on your phone or purchase one from online vendor recharge.com who charge a small fee and will email the PIN to you.
