3 hours ago
2 hours ago
Any overcharge will remain in your account as credit based on your latest plan you are on.
If you are referring to the $2 credit on AutoPay and referrals. PM switched all members to the Points Reward and everything is converted to points and no more $2 credit.
3 hours ago
You didn’t change plans immediately by any chance did you ? Double check your credit card if one charge is just pending it should fall off . Also check your available funds for the difference . But if both charges are posted then ask support to investigate for you
send direct private message to support .
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
3 hours ago
3 hours ago
@leslie3 wrote:credit card overcharges, need to talk to somebody.
Is the amount higher than expected or if your card being charged mulitiple times unexpetedly? Some customers are still unware of a change to the rewards system that caused the amount of discounts to be diminished for many customers.
