number transfer/port from Virgin not working!
Toffeee
I tried to transfer my number from Virgin and it's been 2 days I don't have any service! Help!!!
@Toffeee
 if you have no service at all, i.e. you cannot even make outgoing calls and no data service, that is not a porting problem and the porting support team won't be able to help
Instead, it is a problem with sim card provisioning.  Easy fix for PM support, but you just need  to submit message  with them here:
hairbag1
@Toffeee
is your old Virgin account still active ? Did you leave the Virgin sim in the phone ? Did you receive the SMS and you replied Yes within 90 mins ? If so, plug the PM sim in the phone and giv'er.
Chalupa_Batman
Hi @Toffeee
I'll send you the porting team number. Top right corner mail box. If you put your VIrgin SIM card in, do you still get service?
