number transfer issue
Justina7
My payment was completed but insalling esim for number transfer was failed. And I cannot attempt again because it said that my number is invalid. What can I do?
CSA_PM
Customer Support Agent
Hi Justina7,
I sent you a private message. You can view and reply to it by accessing this link: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
@Justina7
there is a chance that the error was there because the Public Mobile esim is already installed and just not properly enabled
On Android:  Check your Sim Card Manager and see if a Public Mobile eSim is there.  If so, make sure it is enabled.
On iPhone: check Settings > Celluar and see if the eSIM is there.  If it is, make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on
if you don't see the Public Mobile esim there, check the Welcome email, there should be a QR code for the esim for you to scan and install manually.  If you cannot find it in Inbox of your email, check also the Spam box.
If the Public Mobile eSIM is there, disable or delete those non PM sim (eSIM/Physical sim).
If the non-PM sim is physical, remove it.  If the non-PM sim is an esim, disable using the SIM Manager on the phone (or set as Secondary and turn off "Turn on this line" for this non-PM esim)
Then reboot the phone and click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, open ticket with PM by private message CS Agent using this link:
**Monitor your Community inbox (envelope icon on the top right) after ticket submitted, CS Agent will reply to you there will reply to you there
HALIMACS
@Justina7
Just confirming you ensured your device mobile SIM settings is set to 'point' to the e-SIM, and not another possible SIM option.
Try rebooting device or resetting network connections.
