eSIM not installed - can't activate
Shandel
Trying to get a cell phone switched over from Virgin Mobile.  iPhone 15.  It was on a physical sim card, however I switched it to an eSim with Virgin today.  I'm having an issue activating the Public Mobile service.  I add the info in transfer number, Virgin account number, backup phone number etc - then when it tries to activate, it's saying "eSim Not Installed".
I've tried restarting the phone with no luck.  Any ideas?
2 REPLIES 2
Shandel
Thank you - I am now speaking to CS_Agent.  Fingers crossed.
slusagm
Reboot phone and try to login again and it could work.
If not working still, ask PM to help Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here:
