not registered
EarthFarm
Phone service was working 4 days.  Then stopped working. Says you are not registered. No service
Indeed, @EarthFarm
Rebooting, resetting network connections, toggling airplane mode on/off, removing and reinserting one's SIM card usually fixes many network issues.  (outages or reception issues aside)
EarthFarm
Got it working. this below worked
Try rebooting phone, remove SIM and reinsert, reset network settings.
Yummy
Where from did you get your phone? Second hand? Kijiji?
Try your SIM in another phone to determine if it is SIM or phone issue.
Service outage might be in your area. Check here but short outages might not be reported...
https://istheservicedowncanada.com/status/telus/map
TELUS Service Status
hycm53
Check if your phone is clean:
https://www.devicecheck.ca/check-status-device-canada/
@EarthFarm
Check if your phone is blacklisted here: https://www.devicecheck.ca/check-status-device-canada/
Can you try your SIM card into another compatible phone to see if services work?
Did you perhaps issue a charge back on your credit card recently?
@EarthFarm
Outage  map in your area:
also try and logging in to your pm account and is the account still active ?
but if you need support here’s the links
Getting help from agent , through automation
  • Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
Or  get direct help from a agent right here in the community
  • Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
