01-06-2023 07:49 PM
my son lost his phone I have no idea if he has an account how do I stop service to his phone number? Is there anyway to speak to a Public Phone representative? Thanks M
Plans
01-06-2023 09:05 PM
@Busterbrown3 wrote:my son lost his phone I have no idea if he has an account how do I stop service to his phone number? Is there anyway to speak to a Public Phone representative? Thanks M
Try calling the number - does it ring and go through to his voicemail? Perhaps there's a chance an honest finder will answer and you'll get it back.
If the device was registered to a Google account or apple (iCloud) account, perhaps a find my phone service may work for you. This would require logging into the google or apple account to utilize the service.
Give it a shot.
01-06-2023 08:03 PM - edited 01-06-2023 08:03 PM
Try different emails it could be and use the Forgot you Password option. Remember only one unique email per account is allowed.
If you can get logged into My Account then...
See how to report lost / stolen: https://www.publicmobile.ca/en/on/get-help/articles/lost-or-stolen-phone
See "How To Change Your SIM Card" at the bottom of this Help Article: https://www.publicmobile.ca/en/on/get-help/articles/sim-swap-fraud
If issues with your My Account, click here to request a SIM Swap with the Public Mobile Customer Support Agents (CSA): Submit ticket for a SIM SWAP
Edit to add tag @Busterbrown3
01-06-2023 08:01 PM
Find out first IF he has an account and service with PM.
Basically somebody has to log in into account and report phone as lost/stolen which will suspend service immediately.
01-06-2023 07:55 PM
- Login into your account
- Click on Profile
- Report lost/stolen phone
01-06-2023 07:54 PM
How long ago did he get the account? If before last July then if he signed up in a store then maybe he didn't create an account.
If he has an account then he can login to it and use the lost/stolen function to self-suspend the service.
There's no speaking to anybody. You or he would need to use the chatbot simon system to contact support. You might find that difficult if you don't know his credentials.
01-06-2023 07:51 PM
@Busterbrown3 @Loggin in to public mobile and disable auto pay but if you still need agent
Getting help from agent , through automation
- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to our Agents. Click here to get started.
Or get direct help from a agent right here in the community ( my preferred choice )
- Alternatively, you can send a private message to our Agents by clicking here. You’ll need to be logged in to your Community account for the link to work
