05-09-2023 01:35 AM
I activated my phone over 24 hours ago and am not able to receive calls or texts. Email is working. How long after activation should it take before this is working?
Service
09-08-2023 12:22 PM
HI @TimMarshall
the porting was stuck. Did you receive a text from your old provider ? did you reply YES ? and more important, your old provider service has been active all along?
i will message you a number to call to talk to porting support team. Call them and they will tell you what happens
09-08-2023 12:20 PM
I have the same issue. Its been 6 days since I switched to Public and I am still not receiving incoming calls or text. I can make outbound calls with no issue. Please help
05-09-2023 06:09 PM
Thanks for the information. I have sent him a message.
05-09-2023 06:08 PM
Thanks for the information. I will check that out.
05-09-2023 05:05 PM
@jaydee75 did you request porting your phone number from another provider? if that is the case, the porting was not completed and hence calls and texts are not coming in
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
05-09-2023 05:03 PM
Thanks for your reply. We don't have another device to try at this time. Yes, when wifi is off data is working on LTE.
It is strange that calls and texts are still not coming in. Can't figure it out.
05-09-2023 10:07 AM
texting should be almost immediate – it’s the calling that may take some processes to complete, namely, porting from another provider.
Try your activated public mobile Sim card in another device which you know is functioning.
Can you receive and make calls on that device?
Also, does your data appear to work without Wi-Fi toggled on?
05-09-2023 02:00 AM
Sounds like the porting is in limbo.
The most important step is to reply to the text from your previous carrier with YES confirming you are porting over to PM…you got 90 minutes to reply or else…what you are getting.
You need to contact a CS_Agent to request to restart the porting process again but remember to leave the old SIM in your phone to reply.
Submit a Ticket on SIMon Chatbot or private message above.
05-09-2023 01:41 AM
@jaydee75 Did you port in your number during activation? If yes, did you authorize the port in request through the Text message you got from the old sim? Does your old sim currently working?
If you didn't port in your number, check if you got charged. Are you able to login to your self-serve account?
