06-30-2021 12:13 PM - edited 01-06-2022 02:39 AM
I checked my plan, I have 3GB data left. I have removed the sim for 5 minutes, when I put it in no change. I've had my same phone on the same plan for 6 months. I am in a different city. What can I do to restore access to data?
06-30-2021 01:13 PM
Often having set your data limiter is the culprit. But it's better to have the ability to reset your data limit to continue using data rather than find out you have used all your data by an errant app or disconnecting from wifi accidently.
06-30-2021 12:42 PM
@HRHerr : There seemed to have been a data outage in some places overnight. Seems a restart got it going again when it got fixed. Of course turning on data always helps. 🙂
06-30-2021 12:40 PM
Sometimes the cell phone gremlin does that once in a while. 😉
06-30-2021 12:19 PM
It looks like PM's self-serving approach works very well!! 🙂
Great it is not much complex issue.
06-30-2021 12:19 PM
case closed 🙂
No worry.. this thing happens. As long as it all works out in the end.
06-30-2021 12:17 PM
I just figured it out. Somehow I had turned off mobile data on my sim cards And mobile data settings.
