05-07-2021 01:42 PM - edited 01-06-2022 02:39 AM
Hello, I've recently switched to Public mobile and then I went to Russia. It seems that it doesn't work here at all, I wanted to keep my Public mobile sim on to receive texts or voicemails for the next couple of weeks. But it doesn't pick up any signal, unfortunately.
05-07-2021 02:45 PM
@ds4 for texts you are completly out of luck* for vociemails install fongo get a canadian number and use that to access voicemail.
* if sms are important then you need to have a friend in canada buy a simcard, do a sim swap (via moderators) and install the sim an old android phone** and install an sms to email app. at this point you could also forward all your calls to your fongo number once the new sim is activated
** not sure of teh process setting up on iphone
05-07-2021 01:48 PM
@ds4 Sorry no roaming outside of US. In fact all Tier 3 providers are like this.
Maybe you need to consider installing some VoIP app like Fongo. You will get a Canadian number for you to call or for people in Canada to call you for free
05-07-2021 01:47 PM - edited 05-07-2021 05:08 PM
Unfortunately, PM only offers roaming in the US. You could purchase a local sim or use Wi-Fi apps like Textnow, Skype, or Signal.
05-07-2021 01:44 PM
@ds4 : Public Mobile only works while in Canada or having roaming add-ons in the US. Nowhere else. No in. No out.
