08-24-2024
07:26 PM
08-24-2024
08:07 PM
computergeek541
08-25-2024 02:01 PM
@chanhoichu wrote:still no internet connection on 25 Aug. I tried resetting and changing network mode. Doesn't work.
Have you tried your SIM card in a different phone?
08-25-2024 01:37 PM
08-24-2024 07:42 PM
Hello @chanhoichu
Depending on your location, there were reports of issues today. You can check this link and compare it to your location.
https://www.telus.com/en/qc/outages
08-24-2024 07:32 PM
No issues with my service today, I am the Toronto area.
You will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
08-24-2024 07:30 PM
did you check My Account if your data all used?
if not, try reboot phone and Reset Network Settings , try data in different area. Change network mode from Automatic to 4G/LTE and 3G to test each
if possible, test the sim card in another phone
