4 hours ago
3 hours ago
log in to your account / My Rewards & Visit My Rewards / Browse Catalogue...then review the options. Make sure you have enuff Points for the add-on of your choice.
4 hours ago
Here is the help article on redeeming points for data:
https://www.publicmobile.ca/en/bc/get-help/articles/redeeming-public-points
Let us know if you have more questions.
If you need to purchase data add ons frequently, it may be worth upgrading your plan. In your self service account, check which plans are available to you.
