new activation
john210
I was not able to answer the text and I called bell and they said to have PM cancel and send a new port request with correct name and address to transfer my phone number.
darlicious
@softech
You should correctly identify the telus porting department as the the phone number you will provide to customers via private message. Calling it "live support" gives the impression that there's a phone number for public mobile customer support when there isn't.
john210
thank you this looks like it is working, very helpful.
HALIMACS
@john210
To re-initiate the port, click here: https://urlshortner.tiia.ai/Lc9xk8
Then make sure to place your prior provider SIM card in device, await text for port authorization, reply "YES", then replace with your newly activated Public Mobile SIM card.
@john210 @I’m confused are your trying to port in to public from bell or port into bell from public ?
@john210 porting in from Bell?
if so, There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox.  Check the envelope icon on top right.  Call them and get it fixed
