03-17-2023
12:14 PM
03-17-2023
03:08 PM
computergeek541
Hi all,
(new activation will be porting over current number from Virgin Mobile)
I've tried all the suggestions:
-tried clearing cache
-tried incognito mode
-tried restarting fresh browser session on every attempt
-tried multiple credit cards
-tried eliminating last digit of postal code (to be 6 digits long....)
-tried new number instead of porting old number
BTW, cannot make sure address matches credit card info because there's nowhere in any step to input an address.
Need Admin help please!
Thanks!
03-17-2023 12:36 PM
@devonbanman Good to hear. I find sometimes they're doing maintenance on the website later in the evening so also cannot login to my account sometimes if it's late.
03-17-2023 12:34 PM
So I tried this last night with no success. Turns out the website must have not been working last night, so I tried it again this morning and it worked first time, no hiccups!
03-17-2023 12:31 PM
Update:
there must have been problems with the website yesterday. I tried again today and the activation went smoothly first try.
Success today: used incognito mode on Chrome browser on a PC
03-17-2023 12:31 PM
@devonbanman Does it give you a specific error? You're right, most basic would be to assign new number to the SIM and port after you've activated the SIM successfully. Have you tried taking the space out between the two parts of the postal code so it's one continuous string instead of removing the last digit? Be nice if it indicated that it was a CC issue or something else.
03-17-2023 12:24 PM
@devonbanman so the activation did not complete?
confirm your number is eligible to port into PM (it is a Koodo site because both Koodo and PM use the same Telus system):
https://secure.koodomobile.com/checktransfereligibilityparrot/checkSingle.do
For credit card, usually the address does not matter, you need to make sure number/postal code/expiry/ccv are correct
If you need further help, please open ticket with PM support using direct message:
